S595 No Tilt
woodfordfeed
Bobcat S595 manual controls has lost its ability to tilt the bucket back. Unhooked the pedal linkage to make sure spool was cycling through full motion, it is. No leaks, no codes. Lock out solenoids are functioning properly. Replaced the auxiliary valve and cartridge, no change. When you hit push the pedal either direction, you can hear the hydraulics cycle as if it were bypassing but it never “relieves” like it normally does when you max out the cylinders. Arm goes up and for like normal.
Bobcat S595 manual controls has lost its ability to tilt the bucket back. Unhooked the pedal linkage to make sure spool was cycling through full motion, it is. No leaks, no codes. Lock out solenoids are functioning properly. Replaced the auxiliary valve and cartridge, no change. When you hit push the pedal either direction, you can hear the hydraulics cycle as if it were bypassing but it never "relieves" like it normally does when you max out the cylinders. Arm goes up and for like normal.
Can you make a video?
