S570 lower bobtach pins movement
crosent344
New member here. Bought a 2016 S570 new for use around the property. Has mostly seen snow removal, but have done some heavy stump removal work for a few days last year. I've been hearing a noise in the bucket area, and have found that the lower left bucket pin will allow the bucket to move back and forth horizontally about 1/2 inch. I grease the machine religiously, but that pin only holds grease about an hour, then I hear it sliding back and forth-clanking noise. Once I grease it again, it's quiet for a while. Is that normal, or do I have wear in that pin? The machine only has 170 hours on it, but it never used to have that much back and forth play in the bucket. Would a new pin and bushing fix it? Is there any harm in leaving it as it is? Thanks for reading.
I posted a couple of videos, one of each side. With a load of dirt, as I travel the bucket clanks back and forth. I never noticed this before, not sure if this is acceptable or not. It does get better when I load it with grease, but then it does it again after 1-2 hrs of use. I did research that there is an oil seal on this pin, wondering if maybe that is letting the grease out. OIL SEAL, 6631067. I don't want to use it until I find out if this will cause damage. Metal on metal is concerning. Is the solution to keep it loaded with grease??? Links: https://youtu.be/N7W2baXM0T8 https://youtu.be/zdY47o0tyb4
Grease will never stayin there stopping side to side movement, you'll need to shim it to stop it. I used nylon rod and drilled a hole in it and cut sections the right thickness in my lathe to to stop any movement, that may be an option for you?
Thank you for your response, I appreciate it. I spoke live with service managers from 2 different Bobcat dealers, and both told me this is normal, and to use a tackier grease. One did say that if the "play" is over 1/4", they sometimes weld a bead on the bobtach to build it up, therefore reducing the back and forth movement. I was still somewhat skeptical of this because it clanks metal on metal if I don't keep grease in there about every hour while in use. This is a somewhat new issue, as it didn't do this until recently. I'm concerned that even if I get the back and forth movement shimmed, I'll still need to grease it every hour of use... I was looking at this video, and was possibly going to try some nylon rope. Though not crazy about doing this on a machine with less than 200 hrs, it does seem like it would pad the bucket movement, and help keep dirt out. I think that is similar to what you are describing with the nylon rod, though hard to visualize. https://youtu.be/Q8_sHSc6hJo
I just reread your post IMO a 1/2 inch is way to much for a new machine , I would look for washers or some other shim stock and get it down to no more than 1/4 inch. they rope idea will work as a temp measure.
Will do, thanks!
