Hello, I just bought an unit with the hour display panel broken, and I wanted to replace it to read the errors and so on- and to keep a log from now on of maintenance, So my panel is the standard left hand with the buttons from left to right: Light, Min/idle, Aux, and Message; and since I don't have the options for Idle/min, nor the Aux; I figured I could replace it with a new unit that I found online, now the engine will start and then die, with the new display. Does Bobcat need to re-program this unit? or do I need to buy the exact part number from them, for my other arm and leg? Any help would be appreciated.I run Napa oil,fuel and air filters. Bobcat hydraulic cause I haven’t been able to cross them over.
I am guessing it either needs to be programmed or else proper display installed. Hopefully a dealer could tell you whichHello, I just bought an unit with the hour display panel broken, and I wanted to replace it to read the errors and so on- and to keep a log from now on of maintenance, So my panel is the standard left hand with the buttons from left to right: Light, Min/idle, Aux, and Message; and since I don't have the options for Idle/min, nor the Aux; I figured I could replace it with a new unit that I found online, now the engine will start and then die, with the new display. Does Bobcat need to re-program this unit? or do I need to buy the exact part number from them, for my other arm and leg? Any help would be appreciated.
