you say no belt , so you have the hydraulic motor style fan , it should not even come on when you start up , there is a switch that activates it when the temperature gets up and it will go off and on while running , maybe thats what you are hearing , it is load when it kicks in and sounds like a supercharger --------there is a filter right next to it that is dedicated to just the fan motor , I think I would change it and drain the old one into a clean container and look for particles , also maybe cut the filter open and check the media for pieces of the motor coming apart , there was a problem with early models fan motor and another motor came out that replaced it
