Hello all I’m new here , I just bought a s250 joystick machine with 2 speed and high flow, it has 5,000 hrs on it Here is the issue , when you start the machine and push the operate button the machine shuts down the engine and throws a code stating the right side has an uncommanded movement. Once in a while I can get it to stay running when I push the operate button and the right side continues to move in the forward direction slowly at all times until I lift the seat bar , I have tried calibrating the machine but it won’t finish calibration due to the right side never stopping. Also when the machine does stay running in iso mode if I pull straight back on the joystick the machine turns to the right unless I hold the joystick to the right just a touch , if I push the joystick forward the machine moves just fine , straight . I’m about to pull my hair out on this thing any help is much appreciated Thank you
