S205 with deluxe instrument panel
Ranchguy
Neither panel lites up, machine starts, runs for 5 seconds and shuts off. Have 12.5 volts at deluxe panel, lites a light. There is 119 ohms between the purple and purple with white stripe. New battery. Checked and cleaned batt terminals and grounds on engine. Please help.
Check relays/fuses under the metal cover below seat, two 13mm bolts. Had same issue on my s175 and it was a bad relay, it's open cab but still had a relay in the box for A/C, I swapped it with the "computer" or "power module" relay and it fixed it. I forget what they called it exactly.
