I'll give it a try this weekend. ThanksAre both pedals sticky or just the lift? First check that the pivots on the pedals aren't rusted up. If they are free then probably rust in the detent cap on the control valve spools. They can be tricky but are serviceable without removing the whole valve. Remove the 2 bolts at the rear of the control spool and when you remove the cap you'll find some detent balls and springs which will need to be replaced.
Now my low oil pressure light/warnings started to alert. and shut down I checked the oil and even changed it out with a new filter. Same alert after that. I only have 600 hours on it.I'll give it a try this weekend. Thanks
Sounds like a bad oil pressure sender, t a guage into it to veryify you have oil pressure or just try a new sending unit. On the block right near the starter.Now my low oil pressure light/warnings started to alert. and shut down I checked the oil and even changed it out with a new filter. Same alert after that. I only have 600 hours on it.
I just got to my shop and My little Brother added a gallon of Hydro. fluid now the bubble is at the top of the gauge. Will this hurt it? or do I need to drain it out and put it in his lunch box> Brothers, just when I thought he was done growing, he started growing a brain on me.Sounds like a bad oil pressure sender, t a guage into it to veryify you have oil pressure or just try a new sending unit. On the block right near the starter.
I say put it in his lunch box....I just got to my shop and My little Brother added a gallon of Hydro. fluid now the bubble is at the top of the gauge. Will this hurt it? or do I need to drain it out and put it in his lunch box> Brothers, just when I thought he was done growing, he started growing a brain on me.
Ken, Mine looks like its just to the right of the dipstick (not my brother)Sounds like a bad oil pressure sender, t a guage into it to veryify you have oil pressure or just try a new sending unit. On the block right near the starter.
Could it be just to the right of the dip stick?Sounds like a bad oil pressure sender, t a guage into it to veryify you have oil pressure or just try a new sending unit. On the block right near the starter.
Ken, you got it . Thanks. I need a 30 auger bit, can you quote me fob 91701 Ca. Thanks, RobbySounds like a bad oil pressure sender, t a guage into it to veryify you have oil pressure or just try a new sending unit. On the block right near the starter.
Sure thing, 2“hex or 2 9/16“ round?Ken, you got it . Thanks. I need a 30 auger bit, can you quote me fob 91701 Ca. Thanks, Robby
