Hello I have been having multiple intermit codes/problems on my S185 two speed with ACS. The most common code is 3250 Tilt cylinder short to ground. However once in a while get these also: 3239 Lift actuator not in neutral,or 3235 Tilt handle pedal not in neutral or 3249 Lift actuator short to ground. Low rpm's will cause the error to be more frequent. I ran it today for a few hours stacking round bales and only had the 3250 twice. I can't find a rhyme or reason to what causes the code to appear. I also think that I have some hydraulic valve problems because when I tilt all of the way back my Bobtach pins will start to engage. It seems like somewhere a valve is bleeding by. I also have no power turning while in high speed mode and it seems a little jerking going in and out of two speed mode. Any advice on any of the above problems is greatly appreciated.
