S185 Lift & Tilt Cylinders
dee
Hi Yall, Does anyone know what the symptoms are if you have bad seals in the lift and tilt cylinders on a S185
I'm pretty sure that if you have bad seals it would possibly leak externally. I also think that there are internal seals where if they are bad the cylinder will "leak down"????
Exactly
Internal piston seal leak, the ram will slowly drop. Pressure seal on the rod failure, you will get oil leaking out of the ram, you'll see that one.
Just do note that a few inches per hour fall is acceptable without a bucket on the machine.
