S185 how to tilt cab?
Mk4jetta
Id like to til up my cab to take a peak at my chains as my bobcat clicks as it drives. Can someone walk me through this? If easier by phone i can provide toll freee numbers to reach me based on weither your calling from the us or canada. Thanks in advance
1 877 644 9560 if your call originates in the states. Or 1 888 210 9890 ext. 1 , if your call originates in canada
Lifting the cab is easy but that is still a long ways from looking at the chains. remove the two 3/4 inch bolts in the front corners of the cab and lift. Then consult a service manual as you need to remove the plate on the top of the chaincase, brake solenoid, and a bunch of other crap. Have you jacked each wheel up and checked the play in the chains by rocking the wheel back and forth? A couple of inches of play is normal. Drive chains are pretty low maintenance in a Bobcat so your problem may lie elsewhere. I have put thousands of hours on 853's and S185's and never even thought about the chains. Just checked the oil level in the chaincase.
Service manuals can be downloaded here: http://www.mediafire.com/?sharekey=31fe914bdce0f59019747bd91027d4ddf46528a8107c8e29
