Contractor
- Joined
- Sep 18, 2011
- Messages
- 6
Our oldest bobcat was overheating and had basically just been abandoned in our yard. I finally brought it into the shop and pulled the head. As Tazza has stated in other posts it most likely wasn't just a head gasket, it was cracked from he water jacket to the outside corner. I also pulled one bent pushrod out. Found a complete head online and upper gasket set. $ 840 for both. Im hoping it was a cocked valve guide in the old head that caused the valve to stick open and bump the piston. The pistons and bores look pretty good. But I'm having trouble locating a replacement push rod. I suppose Ill check with my dealer, but they are awful proud of the parts there
. Id post some pics if I could figure out how. Is there anything else I need to look for as to the cause of the bent push rod? Thanks ! Cole
