Wirenut2266
- Joined
- Jul 10, 2011
- Messages
- 49
Hello fellas: Just got around to hooking up my log splitter to the S185 awhile back and works sweet. Plenty fast and more then enough power. I would like to possibly ease pressure on my splitter though. While BC is about 1/2 throttle and splitter is not splitting a log or on the return stroke, pressure gauge on splitter inlet is about 500 psi. I'll assume because of shear volume of fluid from BC, which is not on high flow, just variable flow. Lines are 1/2 to/from BC. I suppose I could throttle down BC, but would like to know other options, or is it even an issue? Work ports on splitter valve valve are 1/2", inlet/outlet are I believe 3/4" and are bushed down to 1/2" for the line to the BC if I remember. Just leave as is or a better option out there? Thanks, Bruce
