Bobcat Skidsteer Forums
S175 Tilt Issue
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 87491" data-attributes="member: 82"><p>Glad it was so simple, sadly it's not uncommon for this nut to come un-done. They are meant to be held in place with loctite so they don't move.</p><p>The drive belt, i have used a bar to hold tension on it and tighten the lock bolts down. The hardest part s to get the pointer on tensioner to move if it's stuck. It should point to the 3 O clock position.</p></blockquote><p></p>
[QUOTE="Tazza, post: 87491, member: 82"] Glad it was so simple, sadly it's not uncommon for this nut to come un-done. They are meant to be held in place with loctite so they don't move. The drive belt, i have used a bar to hold tension on it and tighten the lock bolts down. The hardest part s to get the pointer on tensioner to move if it's stuck. It should point to the 3 O clock position. [/QUOTE]
Verification
Post reply
S175 Tilt Issue
