Bobcat Skidsteer Forums
S175 Maintenance Recommendations
Reply to thread
Message
<blockquote data-quote="skidsteer.ca" data-source="post: 14703" data-attributes="member: 307"><p> <table style='width: 100%'><tr><td> </td><td><div style="text-align: right">Skin: </div> </td><td><div style="text-align: left"> default</div> </td><td></td></tr><tr><td> </td><td><div style="text-align: right">View Posts: </div> </td><td><div style="text-align: left"> Oldest first Newest first</div> </td><td></td></tr><tr><td> </td><td><div style="text-align: right">Avatar: </div> </td><td><div style="text-align: left"><br /> Upload an image to show next to your posts (must be 80x80 pixels). </div> </td><td> </td></tr><tr><td><div style="text-align: right">Current Avatar: </div> </td><td><table style='width: 100%'><tr><td><img src="https://www.skidsteerforum.com/DesktopModules/AdverForums/UserIcons/skidsteer.ca_307.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="width: 80px; height: 80px" /></td></tr></table></td><td></td><td></td></tr><tr><td> [TD]<div style="text-align: left"> Display my icon</div> </td><td></td><td></td><td></td></tr><tr><td> [TD]<div style="text-align: left"> Enable email tracking</div> </td><td></td><td></td><td></td></tr><tr><td> [TD]<div style="text-align: left"> Hide read posts</div> </td><td></td><td></td><td></td></tr><tr><td> [TD]<div style="text-align: left"><br /> Use HTML Editor (Free Text Box)<br /> <br /> <table style='width: 100%'></table><p><br /> The 2 inline filters are "case drain" filters for the drive motors and are mounted in a small hose 1/2 way between the front and rear tire, one on each side of the machine. Lift the cab and look for a aluminum canister 1/2 the size of your fist. I doubt you will find much in these. hey are basically a bronze screen, you can replace or rince them at your discretion. They really only get debris in them if a wheel motor is failing. You need a coupler large wrenches to unscrew the canister to acess the filters.<br /> All other filters lube, hydraulic and fuel are spin on.<br /> We use a Texas Refinery grease, it a real heavy red grease and sticky as the day is long. In the winter we switch to their lighter stuff just so you can pump it. <br /> But generally any good multipurpose grease will work. In the grand sweep of things its usually more about how often it gets greased then what grease you use.<br /> Ken<br /> </p></div> </td><td></td><td></td><td></td></tr></table><p><br /> Go to the profile link at the top of the page, open it and put a check in Use HTML Editor (Free Text Box) at the bottom of the profile page and you will have paragraphs.<br /> Example<br /> <br /> [/TD]<br /> <br /> [TD]<br /> [/TD]<br /> <br /> [TD]<br /> [/TD]<br /> <br /> [TD]<br /> [/TD]<br /> [/TD]<br /> [/TD]<br /> [/TD]<br /> </p></blockquote><p></p>
[QUOTE="skidsteer.ca, post: 14703, member: 307"] [TABLE] [TR] [TD] [/TD] [TD][RIGHT]Skin: [/RIGHT][/TD] [TD][LEFT] default[/LEFT][/TD] [/TR] [TR] [TD] [/TD] [TD][RIGHT]View Posts: [/RIGHT][/TD] [TD][LEFT] Oldest first Newest first[/LEFT][/TD] [/TR] [TR] [TD] [/TD] [TD][RIGHT]Avatar: [/RIGHT][/TD] [TD][LEFT] Upload an image to show next to your posts (must be 80x80 pixels). [/LEFT][/TD] [TD] [/TD] [/TR] Go to the profile link at the top of the page, open it and put a check in Use HTML Editor (Free Text Box) at the bottom of the profile page and you will have paragraphs. Example [TR] [TD][RIGHT]Current Avatar: [/RIGHT][/TD] [TD] [TABLE] [TR] [TD][IMG width="80px" height="80px"]https://www.skidsteerforum.com/DesktopModules/AdverForums/UserIcons/skidsteer.ca_307.jpg[/IMG][/TD] [/TR] [/TABLE][/TD] [/TR] [TR] [TD] [TD][LEFT] Display my icon[/LEFT][/TD] [/TD] [/TR] [TD] [TR] [TD] [TD][LEFT] Enable email tracking[/LEFT][/TD] [/TD] [/TR] [TD] [TR] [TD] [TD][LEFT] Hide read posts[/LEFT][/TD] [/TD] [/TR] [TD] [TR] [TD] [TD][LEFT] Use HTML Editor (Free Text Box) [TABLE] The 2 inline filters are “case drain” filters for the drive motors and are mounted in a small hose 1/2 way between the front and rear tire, one on each side of the machine. Lift the cab and look for a aluminum canister 1/2 the size of your fist. I doubt you will find much in these. hey are basically a bronze screen, you can replace or rince them at your discretion. They really only get debris in them if a wheel motor is failing. You need a coupler large wrenches to unscrew the canister to acess the filters. All other filters lube, hydraulic and fuel are spin on. We use a Texas Refinery grease, it a real heavy red grease and sticky as the day is long. In the winter we switch to their lighter stuff just so you can pump it. But generally any good multipurpose grease will work. In the grand sweep of things its usually more about how often it gets greased then what grease you use. Ken [/TABLE][/LEFT][/TD] [/TD] [/TR][/TD] [/TD] [/TD] [/TABLE] [/QUOTE]
Verification
Post reply
