Bobcat noob
- Joined
- Feb 15, 2015
- Messages
- 1
When it does, the level light blinks. It may correct itself with the operate button, a restart, or it may take a half hour of sitting to unlock again. Sometimes when your messing with the buttons to get moving again you can hear the actuator or solenoid cycling by your right foot. I've read that if it is a 13-56 or 13-55 i should try switching connectors to see if the code flips or stays the same to discern if it's and actuator/solenoid or wiring/controller issue. I will look too see if there is any codes this week. The engine does not load up, just the right lever locks up, you still have drive capabilities. Also read that if its an actuator there may be a software update needed as well, any thoughts?
