limited use in last couple months 1600 hrs. Machine died out yesterday. Drained fuel separator to lightly colored brown fluid. Replaced filter and was good for an hour of use.
today went to run and clear snow after half hr machine died. primer bulb collapsed. Unhooked out hose and tried pumping fuel to no go. Switched bulb around to blow into tank and check obstructions. None. Put bulb back around and checked fuel. 3/4 tanks. Ok maybe gauge goofy? Put like 8 gallons in it to full and pumped bulb right up. Started machine and will run for like 10 min and die. Pump bulb and good for another 10 min….. what gives?
