catnip2377
- Joined
- Jul 20, 2009
- Messages
- 10
I have a 2004 S130 with about 500 hours. I last used it back in Feb to do some snow clearing. After the snow clearing I noticed that oil was starting to come out of the Chain Case level plug at the front. I finally had a chance yesterday to open up the chain case cover (inside the cab) and it was full right to the top. Searching this forum I thought perhaps drive motor seals need to be changed. When I started draining the oil it turns out about 5/8-3/4 of what I drained out was water. Since the machine was sitting the oil/water had separated so it was easy to see exactly what was in there. Unfortunately when I purchased the machine in 2009 I did not open up the chaincase to have a look inside so have no idea of knowing if the water was already in existence. How does the water get into the chaincase? Was it water getting into the chaincase that caused it to fill to the brim? ( I have had an enclosed cab since 2009). Perhaps there already water in there and then the hydraulic leak started causing the level to rise? What would be the best plan of action? Is there a way to test the chaincase for a hyro leak? What areas would allow water to enter the chain case? Sorry for the long read and thank you for your help.
