S 185 Front Auxiliary Out of Range
EFDOMINGUEZ
S 185 Aux. Hydraulics Problem. First time here and from Out of country. Problem: rocker Switch for Auxiliary Hydraulics dead. Description: Operator while using a brush cutter (frequently used) caught a barbed wire and destroyed the bushing assembly (between pump and blade assembly). The whole cutter jammed; you could tell the pump was sending oil pressure but it was jammed. Obtained new bushing assembly and replaced. Hydraulic oil re-filled. Everything works (start / stop traction, bucket up, down, tilt) except the auxiliary hydraulics. Nothing happens when switch is engaged…. Hoses are dead… Display has 2 error messages: Hydraulic attachment filter clogged and “front auxiliary out of range high”. It seems like we did not re-install the hoses, correctly, or something was damaged when the jam happened… Any suggestions? Thanks for the help.
I'd check the fuses to be sure something didn't pop when the damage happened.
