S 175 bobcat
lockrotor
new to this forum looking for some advise? I have a S175 that was used on fertilizer from the co-op. Want to remove cab to sand blast all rust off and repaint. Can the unit be rolled back and forth without damage to hyd. system?or is there a bypass value somewhere? And were would you go to find some used parts that I would like to replace? Thanks Lockrotor
Too remove the cab is easy. Unhook the main fraim harness, heater/ac hoses. Remove the cab hinge bolts and you're done! It's not the hydros you should be conserned about. Bent pushrod/connecting rods. Time back on it's wheels would be good. What parts?
