Thanks for your reply, I'm thinking it is a corroded connection somewhere. I switched out the panel with another one just like it from a T190 and still having the run/enter issue.Low voltage will cause that issue but it can also be the panel itself. I usually downgrade the panel to key start panel if it is bad. First check the battery and connections.
