Right foot pedal (bucket lift) is stuck or wont move on a 2002 753 Bobcat
SD753
My machine was down for awhile but I just serviced it and everything is running perfectly except the right peddle. It's has no movement whatsoever. The left foot pedal (bucket tilt) works perfectly. I have no codes at all which is why I don't think it's a wiring issue. Any advice or help would be much appreciated. Thanks!
Make sure that there is no debris under the pedal.
Check to make sure that the lock is releasing on the right side when the lap bar is in the down possition.
Check the pedal linkage all the way back to the control valve to make sure it is in good condition and nothing is jamming it up.
Thanks! I'll do that for sure
A bit late, but those squarish white Teflon pads that the lap bar hits when down, can wear enough to not release the pedal lock. I have to change them maybe every 3 years.
