It's highly unlikely that you'll find a direct replacement. Looking through the online parts catalog, there are different part numbers for the tubes that go to the aux fittings for the standard and high flow, probably due to the difference in diameter and thread sizes.
There should be an adapter union on your machine, (45K7 item 5 in the breakdown), that goes between the supply tube and the coupler.
If you could get that off and take it to a hydraulic shop with whichever flat face coupler you'd like to use, they might have one that will allow the two to work.
I've noticed that OEM part sellers are pretty cagey about not supplying pertinent info, like threads on couplers so you can't find a similar that don't have their brand on it. Your OEM coupler numbers 6598757 and 6598758 are easily findable online, but there is no technical info on them, other than what they fit originally.
