My Timing Gear Case Cover is leaking oil near a bolt directly below where you fill the engine with oil on my 853. From looking at the Service Manual it looks like there is one long O Ring (#20) that goes in a groove on the backside. When replacing the O Ring do I also have to replace the crankshaft front oil seal (#19) that is in the cover if it is not leaking? Should I replace it since I have the cover off? Do I also have to replace the Gaskets #21 and #18. Not sure what those are for? How hard is this to do with the engine in the machine?
Thank you, Greg
width=95%>
Thank you, Greg
width=95%>
