One of the hydraulic lift arm hoses on my 743B has sprung a leak. The arm in question is on the right side as if you were sitting in the machine. The hoses connect to metal pipes behind the plastic coolant reservoir which I can get to, however the connections to the hydraulic arm are inaccessible. Was wondering how to get to it. I was thinking of first removing both hoses at the metal pipes then removing the lift arm pins and seeing if I can just take the hydraulic cylinders out with the hoses. Anyone done this before have any tips or is there a better way? Thanks, Orlando
