Bobcat Skidsteer Forums
Replacement engine for an 843 Perkins 4-154
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 35024" data-attributes="member: 82"><p>That machine is the last in the series before they went to an east/west setup with a drive belt to connect the motor with the pump. The newer ones in the same size run a 3.3litre turbo Kubota or the older ones ran an oil cooled turbo detuz. You may be able to get the Kubota to fit, but again, you have the blower issue....</p></blockquote><p></p>
[QUOTE="Tazza, post: 35024, member: 82"] That machine is the last in the series before they went to an east/west setup with a drive belt to connect the motor with the pump. The newer ones in the same size run a 3.3litre turbo Kubota or the older ones ran an oil cooled turbo detuz. You may be able to get the Kubota to fit, but again, you have the blower issue.... [/QUOTE]
Verification
Post reply
