NYDiggerman
- Joined
- Aug 18, 2013
- Messages
- 39
Had to replace front input shaft on my 743 after U joint disintegrated. Also replaced vane cartridge on my hydraulic pump while I had it apart. Now I have it back together and I have no movement of drive or hydraulics. If something was wrong in transmission it should still pump from the front half. I loosened the out put line on the hydraulic pump (not running) and had oil. I had to push it into the garage without it running. It was hard going but I just overpowered the motors. Is there a valve that could be stuck?
