Bobcat Skidsteer Forums
Removing lift cylinders - Model 751
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 46121" data-attributes="member: 82"><p>Generally there is enough space inside the frame to knock the pins right through and inside the engine bay. The only thing that can get in the way is the air intake hose, but you should be able to twist it a little to get it past.</p></blockquote><p></p>
[QUOTE="Tazza, post: 46121, member: 82"] Generally there is enough space inside the frame to knock the pins right through and inside the engine bay. The only thing that can get in the way is the air intake hose, but you should be able to twist it a little to get it past. [/QUOTE]
Verification
Post reply
