Radiator Fan position on an 825
steve911
Hi all, I was changing the oil in my 825, and while the engine was idling and warming the oil, I noticed that the radiator fan pushes air through the radiator from the engine side and does not "suck" air through the radiator from the outside. The radiator was replaced in 2004 by the previous owner. Is this the way the air is supposed to pass through the radiator or did the radiator fan get put on backwards? thanks Steve A.
The fan assembly is a pusher type, there is a stamp near the hub of the blade its self indicating a pusher type and engine side, most rear engine equipment is like this, the draw back is any oil leak is blown into the radiator fins and clogs it pretty quickly. Good luck, jeffco
