Purging oil from new/old attachment
nirias
I just purchased an old snow blower that I intend to use on a reasonably new bobcat. Should I just hook it up and run it or should I be worried about water or other contaminants in the small amount of fluid that remain in the blower? I know people regularly rent attachments and just hook them up but I'm wondering what risk is involved if the attachment has dirty oil. Will the bobcat's filter catch any crud that might be in the oil or is there some recommended prophylactic procedure?
I just hook one end to the machine and remove the coupler on the other end over a bucket and activate the aux hydraulics. It won't get the lot but its about as good as you will get.
Top up your oil afterwards of course and re-fit the coupler.
That's how I drain my system, at idle.
Imo the risk of contamination is small.
#1Most likely a careless operator that does not clean couplers. #1 leads to #2
#2 Most likely and worst is a failing hyd component putting steel into the oil. if thats the case your loaders filter is designed to catch it but it may still cause problems. The safest bet for continuos flow attachments would be to buy a return hydraulic filter and fit it to the attachment return line to prevent any debris from coming back into the loader. After you use the attachment awhile, cut open the filter and inspect it for steel, aluminum, etc. By then you should know if the attachment performs normally or not.
I'm in the process of fitting hi pressure supply filters to my attachments so #1 does not seize up any motors on me again.
Purging the oil can help, but the problem is the attachment is cold (be sure the loader oil is warm) and may not flush all the particles out, and second you need to know why the particles are in there. As for water that is fairly unlikely and if it has water you may have serious rust contamination to go with it.
