nobull1
- Joined
- Jan 4, 2007
- Messages
- 196
I just pulled the motor on my 763 to replace the hydraulic pump seal. After getting the motor out we realized that the replacement seal was incorrect for the pump. In all books, breakdowns, etc it shows a snap ring, seal carrier, seal, oring, and a snap ring to hold the bearing in. In my machine it is snap ring, metal ring seal, snap ring. The seal is for arguments sake 3” od by 1” id on my machine. The seal it shows in the book is 3/4” id by 1.75'” and a carrier to make up the extra 1.25”. Now the problem is the direct replacement seal (and old one) is not a vitcon so will not take the heat well. My guess is that is why they changed to a carrier system and a different seal. Unfortunately the new seal from Bobcat is not the right id for my pump so I don't know if the carrier would work either So with all the work to change this seal I really don't want to have to do this again. My thought is if I was to make a seal carrier the proper od to fit the pump and the proper id to fit a new seal, I can use a top quality vitcon seal and just make the carrier the proper id for the seal and buy the proper fit for the shaft and know I will never have this problem again. The only issue I have is how/and what to make the carrier of so to seal the carrier od to the pump (seal material will seal the new seal to the id of the carrier. An interference fit would be lucky to not have a leak IMO. The carrier will sit against a snap ring in the back with a washer and snap ring in the front to hold it in place. Any suggestions as what to do would be appreciated. I am going to make a decision tomorrow of what to do, as I don't want the machine to be down too long.
