I'm still having lift and tilt problems on my 763 1998. I took the HYD. block off and noticed the main regulator allen screw was backed all the way out. I wish I would have know about this before taking it off. Anyway I clean it up and painted it. Put it back on and turned the screw all the way in. Put new aw46 fluid in. Fired it up and tried the bucket. I now have tilt down working enough to lift the tires off the ground barley. I drained fluid down and happened to notice very very small metal particles in oil. Not sure if ti was there before ( I'm thinking it was). I removed the gear pump. Took it all apart and notice the internal wall of the pump (only on one side) was worn about 10 thousandth's of an inch. Is this enough to drop psi preventing from lifting? I adjusted the belt to the 3 oclock postion. tried again. Same. While I had the block off I decided to drill and tap the fitting comming out of the pump so I could check psi. I guess I should do that next. What is the likley hood this pump is bad? Jeff
