Prime Mover L1200 Info needed.
lowballlen
Having an issue for locating info for Prime Mover L1200 fuel pump on a diesel in this machine! Any info will be greatly appreciated. Thanks, Lowballlen
If you have the L1200 with the Diesel , I think that is a Isuzu 3AB1 engine.
BTW - I was able to get a water pump AND an alternator this week for that machine.
Prime Mover L1200
Isuzu Diesel 3AB1
Alternator came from AutoZone - Duralast #14129 - Lines up perfect and even the connector matches.
Water Pump came from Amazon - Holdwell Water Pump 5-13610-038-1 5-13610-179-0 compatible with Isuzu Engine G201 C221 C240 with 4 Flange Holes
  • Part number : 5-13610-038-1 5-13610-179-0
  • Reference part number: 8-94376-832-0 9-13610-323-0
  • Other part number: 9-13610-417-0 9-13617-605-0 9-13617-635-0
  • Engine model: G201 2000cc , C-221 2200cc , C-240 2400cc
Only issue was that the fan blade holes needed to be redrilled and tapped to be able to use existing bolts. The replacements would have been TINY and not up to the job. Only took a few minutes to tap and drill them for the correct METRIC bolts ( yes - they are metric )
Prime Mover L1200
Isuzu Diesel 3AB1
I really appreciate your reply. All info is noted and filed.
