hi guys bought a case 1737 it has a case 60 hp combine engine in it . the gear box came loose and pulled the filter fitting out of pump threads in pump are bumed up some what size is it its pipe st. thread right . whats the alum fitting called that went into pump and then into filter . is that jic with a o ring ..also my vary drive 12 inch pulley the side with the spring that slides with the studs going into it has the holes asll ate up bad thewre was bushings i think when new what where they made off can i weld it up whats it made of . also its very loose on the shaft is there a bushing in there to . does enyone have a good verydrive pulley they want to sell need one bad . also how do i tell what engine i have he sayed its a case combine engine 60 hp . fits good in there loos like they had to mod. the ex manifold by woldind but they did a good job . where do i get parts enyone have a manual for a case 1737s they want to sell ......thanks jim
