Bobcat Skidsteer Forums
Pivot Pins 443B
Reply to thread
Message
<blockquote data-quote="MaxW" data-source="post: 57563" data-attributes="member: 7705"><p>Thanks OldMachinist. Using dial gauges makes perfect sence. I'll have to remember that technique. Easy, once someone shows you how. It's always good to learn something new. It also makes sence that Bobcat would use a 1.5" per foot taper because then they could use the tooling and reamers the Truck guys use for ball joints and tie rod ends.</p></blockquote><p></p>
[QUOTE="MaxW, post: 57563, member: 7705"] Thanks OldMachinist. Using dial gauges makes perfect sence. I’ll have to remember that technique. Easy, once someone shows you how. It’s always good to learn something new. It also makes sence that Bobcat would use a 1.5” per foot taper because then they could use the tooling and reamers the Truck guys use for ball joints and tie rod ends. [/QUOTE]
Verification
Post reply
Pivot Pins 443B
