Pin kit question
After looking at a parts list and examining my skid steer, I ended up determining that the kit would meet my needs.
When ordering, the site asks for the serial number range to help listing the correct parts.
Once it arrives (I am in Canada), I will post up regarding fitment, etc.
Cheers
Pin kit install went well.
One bolt wanted to spin, but there is a YouTube video showing how to use a bottle jack and a wooden spacer to hold the bolt head in the space where the tilt pin shoulders are.
It also shows how to remove the grease zerk and insert a (5/16” x 3”) bolt to reach the bolt head. That’s what the bottle jack pushes against.
The only other thing to watch out for is lip that usually forms on old worn parts. I used a dremel with a sanding drum to get rid of the lip on the tilt pin bore so that the grease seals would fit without getting damaged.
It takes a little time working alone, but it is a relatively easy job.
