PERKINS 4108 ENGINE & PARTS Perkins 4108 engine in good running condition for sale including mostly new spare parts for most components of the engine. Selling the engine and spare parts in bulk as a package for the best offer, as listed below. For further information, photos and complete parts list, contact: VK Port Charlotte, Florida 33981 Telephone and Fax (941) 698-5000 Email [email protected] Quantity Description (1) PERKINS 4108 ENGINE (1) MUFFLER 2" Muffler (1) PANEL Instrument Panel Oil Pressure Gauge/Water Temperature Gauge/Volt Meter/Tachometer (1) Fuel Gauge Dial New (1) STARTER with Solenoid (2) Ignition Key Switch (Assembly Blocks) (1) ALTERNATOR #7127NSE, 12 v. (2) ALTERNATOR 12 v. (2) SOLENOID Starter 1 New 1 Used (1) REGULATOR Alternator American Bosch (RAB23A20) #28725135 (1) Fuel Injection Pump/Lucas CAV type 128/ DPA 3743F #37309 (2) Fuel Injectors #2645559 New (2) Fuel Injector Nozzles #33435 New (1) Injector Seating Support New (1) Fuel Injection Pump Tool & Bolts Misc. BOLTS Perkins Engine Bolts (1) Fuel Injection #1 Cylinder Pipe #35355268 New (1) Fuel Injection #2 Cylinder Pipe #35354255 New (1) Fuel Injection #3 Cylinder Pipe #35355263 New (1) Fuel Infection #4 Cylinder Pipe #35354254 New (1) Lift Pump to Filter Pipe #35844057 New (1) Gaskets, Engine, Injection Pump, Etc. (2) WASHERS Injector Seating, 2 Packs est. 12 washers #33811113 New (1) Fuel Lift Pump #2641314 New (1) Fuel Lift Pump #2641314 (1) Oil Cooler New (4) BELTS #2614B129 New (1) PIPE Cooling System Copper Pipe New (2) THERMOSTAT #2485688 (2) CAP Header Tank Fill #2487895 (8) STUDS Cylinder Head Studs, Misc. #0826260 (2) Ignition Key Switch (Assembly Blocks) (1) Seal Cylinder Head Cover #0730116 New (1) Gasket Cover to Cylinder Head #0490724 (1) SEAL Cylinder Block to Housing #2415344 MISC. SEALS Water Pump #NR90001 (2) PLUG Oil Drain Plug (1) Water Pump with New Parts #U5MW0043 (1) Ferrule Pre-Filter #0566003 (10) IMPELLERS Air Conditioning Impellers (1) Oil Seal #SKF NAPA 9826 (1) Valve Kit #30004-0000 (1) Impeller Kit Jabsco #6303-0003 (2) Ferrule Fuel Oil Pipe (1) Sea Water Pump (1) Crank Shaft Pulley #31147637 (2) Engine Lifting Plates (2) IGNITION plugs (1) SWITCH Oil Sending Unit #PS4 (100+/-) GASKETS Misc. Gaskets & Seals Approximately 100 New (1) Parts Catalog for 4107/4108 Engine (1) Service Manual for Perkins 4107/4108 Engine (2) Manuals for Perkins 4107/4108 Engine (1) INVERTER 4000 Watts XANTREX (1) INVERTER LINK 2000 XANTREX New Photographs are available upon request and at: http://fortmyers.craigslist.org/chl/boa/3142250466.html
