part question 2002 Bobcat 800 series
rumrunner
1. How much does the keyless start, with the delux panel option add to the value. 2. Airconditioning value? 3. ACS controls value? Also this unit has 3 hyd ports. One small one and two larger ones one female and one male quick connect. I assume the larger ones ( the M and F ) are the primary hyd and the smaller one is the aux hyd? Is this correct. Thanks for any help guys.
The 3 ports are in, out and case drain. This is for Hi Flow so for general operation you will only use the 2 large ports. ACS can be great and also a curse, when they fail you are up for big $$ to repair, just wait for Shane to comment on that, he loves ACS and SJC.
I'd like to have a deluxe panel for mine, but not sure its worth the extra expense.
Thanks.. One more question..Is there anyway to program the keyless lock out code. Nobody seems to know the code that is in the unit !! There must be a way to re-set it !!
Call your dealer, they can reset it to factory but not sure what info you must provide as they can't tell if you are just wanting to steal a machine with a key less panel. I remember a post about this a year or 2 ago.... Can't remember the details but the dealer found the code after they provided a serial number.
