Other Brand Skidsteer Forums
Kubota/Wacker Neuson/Hesston/IH/Ford/Other
owatonna 330
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 56576" data-attributes="member: 82"><p>I too have never worked on one before, that's why i never replied.</p><p>Kinda sounds like it could be the park brake. How easy is it to remove to inspect.</p><p>How often does it lock up? if it's quite often, can you pull the brake and drive the machine around on flat ground, see if it locks?. Even check how it locks the wheels and see if there are any marks of where it may be biting confirming that it was the brake.</p><p>Just a though.</p></blockquote><p></p>
[QUOTE="Tazza, post: 56576, member: 82"] I too have never worked on one before, that's why i never replied. Kinda sounds like it could be the park brake. How easy is it to remove to inspect. How often does it lock up? if it's quite often, can you pull the brake and drive the machine around on flat ground, see if it locks?. Even check how it locks the wheels and see if there are any marks of where it may be biting confirming that it was the brake. Just a though. [/QUOTE]
Verification
Post reply
owatonna 330
