I have a 742 (Ford FL98 Gas Engine) that has had an overheating issue since I got it a few years ago. It almost seems like the cooling system just can't keep up when the ambient temperature is above 85 or 90 degrees. If it is idleing it is fine, but once I start driving, and/or using the hyraulics the temp steadily rises. Over the last few years I have replaced the water pump, thermostat, radiator, and muffler. The engine was also rebuilt when I got it and I replaced the head on it because the previous head had a crack that had been repaired. The fan is working, the shroud is intact, and the oil cooler is clear. I have also added two elecrtic "sucker" fans on the top side of the radiator. I have tried running it at different RPM's and played with the choke to try different air/fuel mixtures. The timing is also set to the specifications in the manual. It seems to do fine when it is cool outside, but if it is above 90 or 100 degrees, it overheates within about 5 to 10 minutes. Is it just that the gas Bobcats aren't designed for warm climates?
