Working on an old 610 (serial 206837) with seized up variable pitch sheaves, drive and driven. I'm pretty clear on disassembling the drive sheave but removing the driven sheave from the machine is not as clear. I get the jackshafts joined in the center with the split block, no mystery there. Out in the left chaincase the opposite end of the shaft has a 3/8" bolt in it which came right out. It appears that the small chain sprocket is locked to the shaft with two (maybe 1/4") set-screws about 90 degrees apart and I assume that, after removing those set-screws, it will have to be drawn off the shaft with a jaw puller before I can slide the shaft through the pillow block bearing and get the sheave and shaft on my workbench. That's how it looks to me, tell me if I'm seeing it wrong. Couldn't get any size allen wrench to grip in either of the set-screws (if that's what those holes even are, can't quite see in there) so they are either rounded out or missing or ? Am I on the right track?
