Hi I am new to this forum been lurking for a while.
I got this old 453 and have been working on it for abought a year fixing it up.
The trans axle was leaking out all four axles and full of water.
The engine didn't run and boy was it rusty.
I pulled the engine out.
When I was trying to get it started I noticed it had horrifically bad blow by
while it was cranking over. Pulled it apart and found 2 broken pistons and 1 broken rod.
Put in 3 new pistons and rings 1 new rod. Honed the cyls. Put it back together. Runs pretty good know.
This is it with the trans axle and engine out.
The trans axle was big repair. Dissemble, Pressure was inside and out, Sand blast front half. It was serverly pitted. Repair top cover bolts simillar to Old Machinist repair. I read abought it here. Reassemble with new bearings axle seals and speedy sleaves on all four axles. Chains, sprockets and motors were in good shape.
Here it is with the repaired trans axle back in.
Here it is with the engine back in.
I will post some more pic ass I get them loaded up in the bucket.
Hope you enjoy the pic's.
Thanks Art
Thanks Art
