Oil light on 763
Johnboy
Got machine stuck in mud and after getting out oil light is on. About a pint of water got in oil and barely changed color of oil. Only ran for about five minutes and changed oil and filter. Tapped on oil sending unit and light went off then came back on. Engine sounds like before so thinking sending unit gone bad. TIA go any help
Just measure oil pressure with oil pressure gauge, if it between 1 -4 bar, engine is ok - while idling must be > 0.7 on max rpm must be 2-4 . Sending unit is a pressure resistor, i can check readings if yo wish.
you could always tee in a mechanical gauge to verify the oil pressure of the engine as a check of the oil light.
