Noisy Cooling Fan 763
toohp
My cooling fan seems to be getting pretty noisy ( 2800 hrs ) , fan belt & tension seems ok , I recently flushed the oil in the gearbox as it was milky , is it the backlash in the gears that creates the noise or could it be the belt tensioner pulley ? Ive looked at it whilst running but it's hard to tell where it's coming from ? Anybody had this problem or know about .
If you do search on this site you'll find many people have had problems with the fan gearbox. You can buy a new one from here https://www.surpluscenter.com/item.asp?item=13-1422&catname== for $99 plus shipping. Also if you do the search you'll find many helpful tips on replacing it.
Fantastic thanks , I tried a search orig didn't see all that much on it I will try again . thanks Toohp
