[No title]
TLBROWN6657
Been having problem starting my LX865. Figured out that the starter was to week to get enough rpms to start. Took the starter off, and had a new starter silinoide installed. Put the starter back on, and now I have no lights on the instrument panel. The ignition doesn't work either. The machine is in service mode, but not getting any power to the panel, or key at all. I can jump the starter and the machine cranks, and cranks a lot faster than before. I have checked all the fuses I can find, and they look fine. The panel and ignition worked before I took the starter off. Any suggestions?
What comes to mind first is there may be a wire that didn't get connected back to the starter when it was reinstalled. A lot of applications take power from the battery lug on the starter to feed the panel.
Check to see if there is a wire (or likely group of wires) on a large ring terminal that got overlooked.
