No tilt or lift on Bobcat 763
Scaping
I last used the machine about a month ago and had no problems. Tried using it yesterday but have no lift or tilt, am able to go forward and reverse.The system activated, seat bar and valve lights do not light up.Any advice is greatly appreciated.Thank you!
Sounds like it might be the seat bar switch, or the wiring to it. Grab the 763 book from the manual thread and check the troubleshooting guide.
Do a simple test, check how many volts you get at the engine temperature sensor connector (with the sensor disconnected), it should be 8v. If it is more or less, it turns out that you have a faulty controller. This controller can be repaired guaranteed at www.isoscell.com
