No start
RogerRob
I just changed the complete fuel system on my 2019 T770. It started and ran for 5 seconds and shut down. It now gives me a MO309 fault and won't start. Seems to be cranking over well enough but won't start. I used a gas rag and it wants to start but still won't run.
I just changed the complete fuel system on my 2019 T770. It started and ran for 5 seconds and shut down. It now gives me a MO309 fault and won't start. Seems to be cranking over well enough but won't start. I used a gas rag and it wants to start but still won't run. Any ideas of what is happening?
I just changed the complete fuel system on my 2019 T770. It started and ran for 5 seconds and shut down. It now gives me a MO309 fault and won't start. Seems to be cranking over well enough but won't start. I used a gas rag and it wants to start but still won't run. I changed everything. Filter, primer bulb, pump, rail, injectors and cleaned the tank.
Prime the fuel primer bulb until its hard
Cycle the key a few times wait 2 minutes in between cycles
Let me know
Ok, your Battery is weak. If the ECU does not see more then 10.5 V while cranking the ECU will not allow the Engine to fire.
How did you programmed the injectors and all the other parameters?
What exactly did you replaced?
