Georgetravica1
- Joined
- May 19, 2021
- Messages
- 4
Turns couple revaluations and starter stops new battery
Thanks I'll do thatSo probably minor corrosion on the fuse or in the fuse box.
I would be mine full of that fact.
You could have a series of corrosion related issues.
Maybe take the time to pull them one by one, check the plug and clean the fuses at next PM.
For sure that will help prevent future problems. I should have mentioned that.when you clean./check fuses, it also a good idea to add a little dielectric grease to them when putting back, it helps keep corrosion away then
That was my first guess. I agree! Corrosion is another at the wire ends. Check the ground from the battery to the block or ?Check the starter relay. If that goes bad when you hit the key, it will turn over a few cranks and then stop and be nothing. you can then turn the key off and try again, few cranks and then nothing. Starter relay
Too bad we did not get an update!Thanks I'll do that
