offthewall1
- Joined
- Mar 27, 2020
- Messages
- 2
Have a NH lx885 that lost left side drive. Was working fine until charge pressure switch went bad. I replaced the switch and it ran fine for a few hours then left side just stopped. Checked linkages and they're all good. Noticed that there is no whining from the hydrosta pump when I move the left drive handle. I jacked left side up and tried rotating tires and tires would both move just a hair so I'm assuming chain is still in tact. Find some info about capping off the two big hydraulic fittings on top of the pump and slowly work lever with engine running. When I done this the left side pump didn't stall at all. Tried the right side just to verify I was doing the test right, and the right side would whine and stall engine down. I did notice some air when I cracked those two hoses on top of the left side pump. Leaning towards possibly a bad pump but want to be sure before I remove it. I also checked the drive gear for the pump that splines with gear on the flywheel and it is attached and in good shape. Thanks
