NH L250
pilot199
City & State/Province
Louisiana
I've got an early 90's model NH L250. I believe that it's the smallest skid steer made by New Holland. Just found that the idler pulley seized up & melted the belt till it parted. Anyone have experience changing out the bearing on the idler? Also, at this point not sure if I need just a bearing or a new idler assembly. Where would be a good place to find the part? Thanks, Gary
you need to take the idler out and inspect it, some idlers the bearings are cast in place while others are peened or held in by a c clip , so that will tell you as a idler replacement or a simple bearing replacement is necessary.
Thanks for the suggestion foton. Do you know a good parts source?
