Other Brand Skidsteer Forums
New Holland Skidsteer Forum
NH Ignition interlock relay
Reply to thread
Message
<blockquote data-quote="urhstry" data-source="post: 99732" data-attributes="member: 8708"><p>You are correct. I meant the start relay not the interlock relay. Not sure what to do to fix your issue but I also had to put a new ignition switch in (NAPA) and I took my dash out and washed the dirt off it and looked it over for any hot spots or loose connections. It was crusted with dirt. You might want to address both those spots.</p></blockquote><p></p>
[QUOTE="urhstry, post: 99732, member: 8708"] You are correct. I meant the start relay not the interlock relay. Not sure what to do to fix your issue but I also had to put a new ignition switch in (NAPA) and I took my dash out and washed the dirt off it and looked it over for any hot spots or loose connections. It was crusted with dirt. You might want to address both those spots. [/QUOTE]
Verification
Post reply
